GF sanding sealer, anyone use?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50748
Author:  rlrhett [ Tue Jun 19, 2018 9:28 am ]
Post subject:  GF sanding sealer, anyone use?
I noticed that General Finishes has a new (to me at least) sanding sealer product specifically for water based finishes. Has anyone used it, or see any benefit to using it, under Enduro?
Author:  RaymundH [ Tue Jun 19, 2018 11:17 am ]
Post subject:  Re: GF sanding sealer, anyone use?
Their website has instructions on how to use this product. https://generalfinishes.com/wood-finish ... ing-sealer
Oddly, it says not to use it under Enduro-Var?
"Sanding Sealer is not recommended as a final finish because it is not as durable as a topcoat. Seal Sanding Sealer with any General Finishes water-based topcoat, EXCEPT General Finishes Enduro-Var, for improved water and chemical resistance."
Author:  Jules [ Tue Jun 19, 2018 10:58 pm ]
I have used both GF sanding sealer and EnduroVar. The sanding sealer is like other sanding sealers I have used. Because it's WB based, there will be some grain raising. I sprayed it on some kitchen cabinet doors I made, knocked the fuzzies down with 320 and sprayed WB poly over it. No issues.
GF is very adamant about EnduroVar being applied over bare wood and nothing else. I have sprayed it over water-dyed wood on mahogany and sapele w/o issue. A few months ago I did a sample by brushing EV over Minwax whitewashed pine, sealed with GF sanding sealer. I just checked it and didn't see any problems with adhesion.
